Re: Copying Markups Between Different Scales – Is Automatic Adjustment Possible?
vfrench's answer is definitely better than mine, but another way to do this that I use quite often is with the snapshot tool. If you snapshot content and then paste it in another drawing, you can adjust the scale via a percentage in the properties toolbar. I generally like this one because it's great for overlaying plan info from one drawing to another (you can use it not just on markups, but also on any drawing info.)
Problems with this method: you won't be able to edit your markups with this.
Re: How else do you use Bluebeam? 💡
@David Cutler my groundworkers did come and do a survey which was great. Unfortunately, that somehow got deleted so they will come out and do another. It built the full 3D model so you get all the heights of the trees and also do something a bit like street view. Amazing stuff!
Re: Scale by reference
@vfrench posted a comment about this recently @vb&t Brandveiligheid. Short answer there are a number of ways to simplify this process.
Check out the thread below 😎
https://community.bluebeam.com/discussion/6049/copying-markups-between-different-scales-is-automatic-adjustment-possible?tab=accepted#latest
Neat use case @vfrench!
If you wanted to get closer to a scale sketch you could try bringing a satellite photo into your sketch to establish locations. Either that or get one of your vendor friends to come by with a drone… 😎
So I've just found a new use for Bluebeam - mapping out the trees in our orchard.
I haven't gone as far as drawing everything to scale but I've put markups roughly in place of where the trees are and then colour coded for the different types of fruit - apple, pear, cherry, damson and plum. These are also all numbered so when I eventually work out what variety each tree is then I can have a proper record.
This also means that when I make homemade cider I can play around with the combinations of apples from different trees to see what works best.
Join the Bluebeam Studio Project Search beta today!
We’re excited to invite you to join the Bluebeam Studio Project Search Beta!
Studio Project Search is the search function within Studio Projects. It has been enhanced so you can find files, folders, and markups faster.
You can now:
- Search using key words
- Search using natural language (describe what you’re looking for as you would say it)
- Search across all your folders and subfolders within a single Project
- Filter your search by Type, Folder, Created Date, or Modified Date
- Jump to the exact spot in a document where a searched markup appears (Bluebeam on web only)
How to get started?
- Sign up for the Studio Project Search beta here.
- Follow the setup instructions outlined in the program activities to create your Bluebeam ID (if you don’t already have one)
- Complete each test activity before September 15th, 2025
Note that to partake in this beta program, you need a Bluebeam Early Access account and Revu 21.7 (download links will be posted in the project) and/or access to Bluebeam on web.
Thank you! we look forward to your feedback!
What's something you've learned this year? 📚
August is typically associated with Back-to-school season, this means new opportunities and goals. Maybe you picked up a new Revu skill or learned a tip to stay organized.
Learning doesn't stop with school! As part of your personal/professional growth this year, what's something new you've learned?
eperius
⭐Unbound Session Spotlight: Inside Bluebeam Labs: Connected Drawings
Want to look back at the history of Bluebeam's groundbreaking Connected Drawings tool? Get a behind the scenes look at the Bluebeam Early Access Program where you'll learn about the project setup process, lab tester experiences, and much more!
Join us at Unbound on 10/2 at 1 PM to get a sneak peak at the innovative projects in Bluebeam Labs and to learn how to join the Early Access Program!
Have you used the Connected Drawings feature before?
eperius
Re: License ended, Unistalled, Bought new sub. Can't get signed in with new SN
Hi @pcaddle - Thank you for posting in Bluebeam Community! What you’re describing sounds like a scenario for our technical support team. Please complete this form and they’ll be more than happy to assist you!
Re: Tab Order Not Saved?
Could you try:
File, Create, PDF Package, add your 6 files, then pick Open All?
