Re: Tool Labels Disappeared After Update
Hello everyone,
I reached out to support and was able to gain back the hover functionality by following these steps:
- Close Revu
- Open the C:\ProgramData\Bluebeam Software\Bluebeam Revu\21\Revu\FeatureFlags.xml
- Edit the ToolChestUseNew to:
<Feature Name="ToolChestUseNew" Enabled="False" Protected="True" />
- Save and reopen Revu
Please note that "ProgramData" is a different folder from "Program Features".
Summer has officially begun!
June 20th marks the first day of summer! The summer solstice is the longest day of the year, more daylight to get things done!
Do you prefer long summer days or are you more of a fall/winter person? What's your favorite season?
eperius
Re: Summer has officially begun!
Summer is my season, so I'm excited to get it started and then move into an enjoyable fall season as well.
Re: Materials take-off
Generally Speaking, the more you use Bluebeam the quicker and more efficient you'll naturally become at using it however a great place to start is understanding the toolbox functions. I'm in Roofing & Cladding and we have a number of different toolboxes for the various roofing & cladding build-ups we offer as a business. Understanding the full use of the take-off functions is also very beneficial.
Re: Tool Chest Locks
Recently done the same thing for our business… have built 28 different chests with an average of 25 items in each. Would be great to be able to lock this down so everything remains consistent.
Re: ✴️ Feature Highlight: Rotating Measurement Captions
I like this feature as it is makes life much easier when trying to layout a drawing especially when there is a lot going on. One feature I would like to see is that the text actively rotates on the page as I am trying to determine the angle I am looking for.
szutter
Re: Preferred settings for printing markup summary?
We have generally used the table style at my firm, it takes more sheets, and the info is more spread out, but we like that, and it gives room for notes next to each instance. (for example, going item by item in an OAC) Larger spaces also make people write larger, so if people take hand notes on the printout it can be scanned a little cleaner.
If thumbnails are showing, medium and small work digitally because you can zoom in, but in print are most of the time too small to reference or review. We exclusively use large thumbnails as a standard here. I can see the flow style being great to use as a check list/ overall list of markups, but I’d take it into excel to post produce before I showed flow to someone outside of the firm, and the table style I can generally leave as is and still have the conversations I need.
We use both letter size and 11 x 17 sheets for different circumstances, for the padding I’d say the less you have the better unless you have a site walk, more padding adds more white space to the sheet for notes or sketches. Hope this helps!
Re: page #s and labels
@Shelby Here's how I handle it:
First, add the page numbers using the "Header and Footer" tool. Once that's done, use the "Create Page Labels" feature with the "Page Region" option. Include the page number field from the header/footer when setting up the labels.
There may be another way to handle it, and Id love to hear!
Re: Measure Markup will not display
Issue resolved. The "Make Annotations from Measurement" had to be checked.
FYI, online resources suggested this was a checkbox that is directly visible in the Measurement menu. In my setup, this option was hidden. You have to click into the Measurement header which pulls down a hiddent list of options.
Re: How to attach custom properties to tools in Revu21?
Shanoc, The search function is great! Do you know if this will be expanded to search both active and non-active toolsets? Right now, it only searches active toolsets. We have a lot of toolsets and try to only turn on what is being used. If you don't remember where a tool is, sometimes that toolset is off when you are searching for it and Search won't see it.
