New Webhook Subscriptions API endpoints available
Happy Friday, everyone! The Integrations team is happy to share that we have new Subscription endpoints, also known as Webhooks, available on the public Bluebeam Studio API.
⚙️ What's New
- These endpoints allow developers and partners to subscribe to activity and updates made to a Studio Project or Session while building out their integrations.
- Previously a Beta feature in the legacy Prime API, webhooks in the new Studio API will further assist developers and partners migrating their integrations to our new integrations platform.
- Webhooks will also aid in limiting the number of calls developers and partners have to make because instead of checking for Studio updates on a regular basis, they can subscribe for updates, which should help improve system performance overall.
We look forward to seeing developers and partners add webhooks to their integrations and build custom workflows using the Bluebeam Studio API!
Re: ✴️ Feature Highlight: Dimmer
Don't forget there's also the Disable Line Weights tool. This affects all documents including printing options, so be careful to restore line weights when done.
Re: Font size since latest update
To keep your process moving @Vince Fitter you might try using the tools "as is" with the 12 font. Once you are done with your markup you can then "select all" of the markups and change the font back to 3 point. I tried this with one of my files and the process seems to work only when you change the font size in the properties bar that I have positioned at the top of my screen.
Not sure if that works with your process or not, but it might keep you moving. 😎
The fixes seem to have done the trick as far as I can tell. Thanks for keeping us in the loop!
For service company drawings I will often change the original colours to something very pale as the original linework is often so dark and thick that it is impossible to see your markups over them. Dimming becomes unviable if you have several different services all within a 2m wide footpath as you still need to use the colours to make sure you're measuring the correct item.
The Dimmer tool is also helpful when you're marking up a drawing that already has a lot of color. I'll often see mechanical and electrical drawings that use color to differentiate between various systems. Dimming the color content so that color markups stand out makes it easier to navigate.
I'm right there with you @Vince Fitter! The majority of my markup tools are customized with custom column values for my workflows. I'm a big fan of building a tool out completely 1 time and using the benefit of that invested time over and over again.
Re: Are folks using Bluebeam to create dashboard for various project links/information?
Oh yes, I made a sort of user's guide dashboard for my BB Project where we are hosting our conformed sets. It's been a big hit and a huge time saver. Those links provided above should give you all you need to know.
YES!!!! I Love it.. After I posted the comment i did uncover that gem on adding markups to the image. BTW your friend Darrell D. says hi. I was just on the phone with him. And this feature alone of marking on the images will be helping him tremendously in his site inspections… :-)
Hi @Rick Kremer ,
Good to see you on the thread; I hope all is well.
After a photo is "Captured" to a markup, you should see a pencil icon on the left-hand side. As a note, markups are not supported on 360 images or videos.
