Re: Easier path, less steps to save a PDF to an iPad
Right now the path to save a PDF edited with Bluebeam on an iPad are:
- Select the
Send To
icon - Select
Open In
from the options - Then
Save to Files
- From here you can choose to save files to
On my iPad
oriCloud
This is a pretty lengthy process just to save an edited PDF.
Four steps is too many just to save an edited PDF.
Please simplify the process of saving an edited PDF to an iPad.
Thank you
Re: Feedback : Find and Replace
Correct, those search results are not replaceable.
And again, the find and replace will only work once Flattened, and then you will not be able to unflatten.
Thank you for the reply. I have tried to run find and replace after unflattening but still no success. By the way there is only one check box and it is for "Select All". Each instance doesn't have its own selection box. Does this mean the find and replace function will not work?
Re: Modifying Snapshot Properties with Scripts
I believe this request would fall more under Scripts than Snapshot setting, and would be extremely useful for individuals who cannot use the default overlay features. I.E., I do not like creating separate files for my overlays, so the process would look something like:
- Run Snapshot Script
- This would be set to take a clean (no markup full page snapshot)
- Run Paste in place (overlay) Script
- Would paste snapshot from clipboard
- Color Process
- Modify blending properties
- Modify opacity
- Set Layer (Dialogue box?)
- Flatten
- Save file in current location
- Super Bonus
- Being able to run both of these as a singular script from a set of source files to a set of target files as batch…
The current limitation for this is the number and narrow scope of functions available on Script creation (not full javascript api, Scripting under Document/Script and Batch/Script)
I could see this being "set as default" when pasting snapshots or maybe a "style" that can be applied with these preset properties (better if you have multiple versions)
I also love this idea. I use the same properties on my snapshots every time, and I agree it's a little tedious when you're doing a bunch of them.
✴️ Experience using the Tool Chest?
What has been your experience for storing & reusing custom markups in the Tool Chest?
- How do you organize and manage your tool sets?
- What impact has this had on your efficiency?
P.S. Don't forget to check out this month's monthly challenge on Tool Sets!
Re: How do I keep Bluebeam Studio from logging me out of my Studio Sessions multiple times a day?
Hi @Bob Caine This is definitely something the Technical support can have a look at and advise further. Can you please reach out to us using the Contact form? Someone will get back to you ASAP.
Kind regards,
Hercia
Re: Add Folders for Studio Sessions!
I would use this feature if developed. Anyone else?
Hi @bWhite,
Many thanks for your message. The advice Tech support gave you is correct. Although some of our users run Revu on Parallels, this is not a supported environment so there might not be much we can do to help here. The only virtual environment we currently support is Citrix! If you still want our team to investigate this further, can you please raise a Support ticket? Someone will get back to you as soon as possible.
Many thanks,
Hercia
