Re: 📊 Vote for the March 2025 Challenge winner!
You've got some skills, @Doug McLean - I was really inspired by your video!
Re: Bluebeam, please become FedRAMP authorized
I've been asking for this for quite some time, working to increase efficiency in my agency using Bluebeam Revu for our engineering and construction projects (DOE). We are currently using Bluebeam for our unclassified projects, but this is a small piece of the whole pie, and having different workflows is tedious and makes it difficult for folks to adopt.
If Bluebeam made a point to get FedRAMP authorization they would be undeniably the best option to help streamline federally funded AEC projects across numerous federal agencies.
Hopefully I get the chance to show this off at Unbound.
Thanks to everyone who voted for me.
The poll has ended and the votes are in!
Congratulations to @Doug McLean! 🎉
Marco M
Re: Please Add an Option to Remove the Scale for Page
Yes, this is especially important when sharing files. I encountered the same issue with a riser diagram I created without a scale, I mistakenly added a scale to it and now have no way of removing it.
Re: Storage location for toolboxes
BTW, you suggestion is a simple but effective workaround, Thank You, it helps avoid the tedious directory tree climbing & descending.
Re: Select Specific Text Markups in Revu Sessions?
The workaround I have found is to copy-and-paste the other user's markup (can be in the same document). The copy is now your markup, so you can copy, edit, etc., the text as you like.
Adding a GET WINDOW function to the page setting menu might be the best suggestion to the BB Dev's. I kept thinking of that function on this thread but remember it is an Autodesk thing and probably more software that others work with.
