Re: Storage location for toolboxes
BTW, you suggestion is a simple but effective workaround, Thank You, it helps avoid the tedious directory tree climbing & descending.
Re: Select Specific Text Markups in Revu Sessions?
The workaround I have found is to copy-and-paste the other user's markup (can be in the same document). The copy is now your markup, so you can copy, edit, etc., the text as you like.
Adding a GET WINDOW function to the page setting menu might be the best suggestion to the BB Dev's. I kept thinking of that function on this thread but remember it is an Autodesk thing and probably more software that others work with.
Closing BB Session as administrator
Hi, I would like to know if there is any way to close BB sessions made by other user inside my compagny ? By default, when creating session, the permission of session are very limited and closing is possible only by the person who create the session. Thus, is that person quit the company, it should be a way, by the administrator to manage the sessions created by an employe. It is very important when archiving the project.
thanks,
Would it be nice if Web Links in Bluebeam opened in your default browser?
Bluebeam is awesome for drawings etc., but it is not a web browser. Wouldn't it be nice if when you clicked on a web link it would open in your default browser? Unless there already is an option and I just don't know about it.
Movable "Locked" Shapes
I would like another option for locking that allows for a shapes dimensions to be locked, but still be able to move the shape / sketch around. An example of this would be a toggle for "dimension lock" where I could trace the outline of a building and rotate / move it around a site or property without accidentally changing the traced building's size.
Re: Autosize (up) to prevent line wrap
from my experience, seems like I'm almost always wanting consistent font size, and text box expands horizontally.
Plan owner edit another contributor's redlines?
Is there a way to modify the Bluebeam settings so that the plan owner can delete/edit others individuals redlines? We are having an issue where individuals will have internal discussions or put inaccurate comments on the plans. The plan owner then has to ask them to go back into the session and delete said comments.
