Movable "Locked" Shapes
I would like another option for locking that allows for a shapes dimensions to be locked, but still be able to move the shape / sketch around. An example of this would be a toggle for "dimension lock" where I could trace the outline of a building and rotate / move it around a site or property without accidentally changing the traced building's size.
Re: Autosize (up) to prevent line wrap
from my experience, seems like I'm almost always wanting consistent font size, and text box expands horizontally.
Plan owner edit another contributor's redlines?
Is there a way to modify the Bluebeam settings so that the plan owner can delete/edit others individuals redlines? We are having an issue where individuals will have internal discussions or put inaccurate comments on the plans. The plan owner then has to ask them to go back into the session and delete said comments.
Re: Global Session Administrator
This would also be very helpful when an employee leaves the organization. It would save the trouble of resetting the user's password and logging in under their account.
Re: Bug? Bluebeam Hijacks my Windows File Explorer Window
This bug is still present in the current version 21.5.0.8071
Really need some more options for text editing. Basic functions that are available in almost all other software like bulleted lists, indention, change case, etc.
Re: Disappearing Layers
Hi Everyone. I just wanted to say that we are investigating this issue as Thomas submitted it as a bug in the Revu 21.5 beta test. I'm seeing here that many of you are also seeing it. If anyone here is interested I'd love to get some of your log files for when this occured so I could send them over to the QA team. If you would be willing to share that reach out to me at beta@bluebeam.com. I appreciate all your help trying to get to the bottom of this one.
Thanks for all your help. I am a novice at this. I will try this solution and see if it works without losing functionality or triggering some other issues. I understand the notion of telling the program what to do but this seems like a weakness in Bluebeam given that it could be reasonably expected that someone would want or need to provide comment outside the document area. All the Bluebeam guides don't seem to understand this question or are of the view that it can be resolved by simply setting the print area to include the markups which I think I have shown the program doesn't appear able to address. In any case, thanks again.
Re: Relocate Drawing Set Files?
you can't just Move a Set. If you do that, then the file gets all messed up.
If you do a Save As, it reassigns the file path.
The main files do not need to live on the server, we have files on SharePoint and on our local server, works fine
