Re: Quantity Link
Hi @Brent
If you're interested in seeing what you can get out of a Bluebeam and Excel combination then this might give you an idea
Re: Quantity Link
Hi @vfrench,
Thanks so much for the suggestion. Power Query looks like a great option. Now looks like I have some homework to do on using Power Query!
Why is OCR so Bad?
The plans we received from the EOR are a mess when it comes to hidden text, so doing things like creating page labels, bookmarks, or Set labels from Page Regions doesn't work and we basically have to manually edit everything, which can be a pain on a 770+ page plan set. At support's suggestion, they had me Print to Bluebeam PDF to clean all that up and then run OCR. It did improve things, but I still need to correct a lot of sheet numbers. It thinks 1's are 7 or I, it thinks B is 8, thinks W is V \ /, and S is 5. That's just the sheet numbers I'm working with. I can't image how it's messing up numbers on the sheets in general. Here are just a few examples, I fixed most of them before thinking to post.
Re: 💡 Share Your Bluebeam Tips & Tricks!
It appears your links use an old format.
You need to remove "/bluebeam-connect" from the url.
Hello Bluebeam community!
Welcome to the Bluebeam Community, a platform designed for Bluebeamers worldwide to build connections, stay updated, and contribute insight.
This forum can help with collaborations, sharing workflows, and promoting best practices. We’d love to have you share your experiences with Bluebeam and the effective practices you’ve implemented.
To kick things off, we’re introducing our very first badge reward! Follow the instructions below to earn one of your first badges, along with points! For detailed information about our Bluebeam Community Points & Rewards Program, Badges, and Points, please visit the Community Hub forum and review the Welcome Guide FAQs.
To earn your Tipster badge:
- Create a post in the Peer Support forum.
- Add any type of media to support your tip within the post.
- This can be a simple image, video, or link showing what your tip does.
- Provide any details, such as example steps on how a new Bluebeam user might use your tip.
- After you've created your post, come back to this post and create a comment with a link to the post you created.
Once you've commented here with a link, you’ll be rewarded with your badge!
To kick things off, here’s an example:
TIP: Pin a tool/toolset to a toolbar
Pinning is a great way to make your frequently-used actions more accessible. Here’s how:
Pin a tool to a toolbar:
- Navigate to the tool
- Click Pin to the right of the tool
- Select which toolbar to add it to
Pin a toolset to a toolbar:
- Navigate to the tool set in the Tool Chest
- Click the tool set gear wheel
- Click Pin
- Select what toolbar to add it to
We can’t wait to see all the tips, workflows, and best practices the community shares!
Re: Using Layers?
I use Layers heavily for takeoffs. I assign layers by the trade for which the takeoff would be assigned to.
For example, when I perform my Structural takeoffs, I have my layers split up between Concrete, Structural Steel, Misc Metals, Masonry, etc., and assign the takeoffs to each designated trade as my takeoffs continue. That way I can hide each layer and have a blank slate when I begin taking off my next trade.
Each layer can also be reflected as a selected column within the markups list. That way when you extract your takeoffs as a csv file, you can sort, by layer, within Excel. Saving you time when you perform your calculations and add these quantities to your estimate template. Also, you can use the 'filter list' to only show a specific layer and quickly locate your takeoff/markup within the bid documents.
Re: Edit Tool Chest Layout
When you click on 'Manage Tool Chest', select one of the existing Tool Chests and click 'Modify'.
From here, you can edit the name for each tool chest. You can also select the red "X" to delete the tool chest that are no longer used.
As far as the columns continuing to narrow, I do not have an answer for that. I agree with @Brent that the comments column should be removed or at least moved to the right of Label.
Re: Using Layers?
I use them to organize information for the project, my markups, pathways and notes. Heck I use them for change comparisons in areas.
Re: Offset button in measurement
Bluebeam doesn't have an offset feature unfortunately.
However, if you want to draw offset guidelines to measure to, there is a way which works with even the most complicated of shapes.
This uses custom line styles. Have a look at this to see how it is done https://youtu.be/e7n9FeKfzpw
