How can I add width and length of 1 side of a label for markup list?
Example. I need the width of a piece of wood (1) side and the length of that wood (1) side. Not the total length just width and length each independent measurement for the same label.
Answers
  • @Karen Fasenmyer In Revu you can use an area measurement to label a lot of things, but it will see the X axis as width, the Y axis as height and length with show the perimeter of the shape. You can turn on the width and height columns in the markups list to see those measurements in the markups list. In the image below the area measurement provides the information in red. I used blue length measurements to show you how each is labeled. Is this what you are looking for?
