Slip Sheet Suggestions
Florida DOT requires that revised sheets be inserted behind the sheet that they are revising. Slip sheet allows for replacement of the current sheet or insertion before that sheet. Can you add an option to insert it after?
Also, they want the old sheet to the stamped VOID however there is only a check box to stamp it SUPERCEDED. I have revised the stamp to change the word to VOID, but allowing other options (perhaps an available stamps dropdown?) would be nice.
1
1 votes
Active · Last Updated
Comments
  • Alan A.
    Alan A. Posts: 50
    Hi @Scott Cavendish,
    Thank you so much for reaching out to us about Slip Sheet suggestions, and we've taken note of your request. While we may not be able to accommodate every feature request, we greatly value knowing which features are important to you. Could you share more detail about how being able to insert the revised pages after the current page would benefit you?
    Please let us know if there’s anything else we can do or if you have any other questions. We look forward to collaborating in the future.
