Program not registered as started in task bar
I cannot remember when it started, but I am experiencing that when I start Revu Bluebeam from the task bar, it is not recognised as running. If I then open many windows and click the Revu icon in the task bar, to go to Revu, it instead opens a new Revu window instead of going to the original one. The problem has persisted through several updates, and is only resolved once I manually make the Revu window visible, and then clicks in it to "activate" it.
3
3 votes
Active · Last Updated
Comments
  • Having this same issue - also having an issue that is a little related. When I open a Bluebeam from the taskbar and then open a pdf from outside of Bluebeam it will sometimes open a whole new Bluebeam window instead of opening inside the one already open.
